[geos-devel] CascadedPolygonUnion XML testing
G. Allegri giohappy at gmail.com
Fri Jun 25 17:48:33 EDT 2010
This is the reduced version of the test xml:
http://www.giovanniallegri.it/share/TestUnionMultiPolygon_red.xml
Now it contains only two geometries. It tries to node them but fails,
so a second try is done with the SnapOverlay, but it fails too.
I don't know the algorithm so I'm not able, yet, to say what is failing.
giovanni
2010/6/25 G. Allegri <giohappy at gmail.com>:
> Here is a test xml:
> http://www.giovanniallegri.it/share/TestUnionMultiPolygon.xml
> It's big, but I will reduce it nex time :)
> Notes:
> 1 - this multipolygon comes from an st_collect on 95 rows in a postgis
> table. The test on it fails with Topology Expection found non-noded
> intersection, because the MP is invalid. I've tested it on jts from
> trunk.
> 2 - I've run a cascadedunion.union operation on a List of the same
> geometries (picked with Geotools directly from the DB). It works fine.
> In this test I've used jts 1.10 shipped with Geotools. I will try it
> agains the trunk version as soon as possible.
> Giovanni
> 2010/6/25 strk <strk at keybit.net>:
>> On Fri, Jun 25, 2010 at 04:39:17PM +0200, strk wrote:
>>> Martin, is there any support for testing CascadedUnion
>>> with the XML format ? Would help comparing GEOS/JTS.
>> I've found TestUnaryUnion.xml in JTS repository.
>> I guess that's what GEOS should be using
>> for testing CascadedPolygonUnion.
>> Only need to actually port UnaryUnion ...
>> --strk;
>>  ()   Free GIS & Flash consultant/developer
>>  /\   http://strk.keybit.net/services.html
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
