[geos-devel] Problems compiling nightly snapshot
Mateusz Loskot mateusz at loskot.net
Wed Mar 3 09:42:25 EST 2010
strk wrote:
> On Wed, Mar 03, 2010 at 01:23:58PM +0000, Mateusz Loskot wrote:
>> Paul Meems wrote:
>>> But this doesn't work with geos_c.h because it refers to two files in
>>> sub folders. We can do two things: either create the sub folder and copy
>>> the two files in to it or copy geos_c.h and open it and change
>>> geos/version.h to geos_version.h and geos/export,h to geos_export,h..
>>> Currently we do the latter workaround.
>> So, I'm not really the right person to decide if/how to fix this problem.
> Sorry if I ask, but wasn't geos/version.h and geos/export.h being installed
> already by the 'make install' rule ?
> @Mat: could it be a temporary problem created when you changed install rule
>       to put all geos headers *under* the geos/ folder ?
>       (which you should have fixed, but maybe he got outdated version)
Sandro,
AFAIU, the problem is with including geos/export.h in geos_c.h
because it requires users of C API to specify path to geos includes
directory. I did not added geos/export.h to geos_c.h
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
