[geos-devel] Re: [GEOS] #344: After applying a buffer over a
multiline the library starts growing in memory usage and hungs
geos-trac at osgeo.org
Fri May 14 05:25:00 EDT 2010
#344: After applying a buffer over a multiline the library starts growing in
Reporter: sberna | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.2.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by sberna):
Replying to [comment:2 strk]:
> Replying to [comment:1 sberna]:
> > Both geometries are reported as valid by the library.
> Note that GEOS-3.2.1 contains a fix for a bug giving false positives for
ValidOp.
Downloaded GEOS-3.2.2 to test both geometries, and no changes. Both
geometries are reported as valid and the buffer operation crashes.
Ticket URL: <http://trac.osgeo.org/geos/ticket/344#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
