[geos-devel] Re: [GEOS] #344: After applying a buffer over a multiline the library starts growing in memory usage and hungs
GEOS geos-trac at osgeo.org
Fri May 14 08:44:33 EDT 2010
 Reporter:  sberna      |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:
Component:  Default     |      Version:  3.2.0
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment (by strk):
 wow, I confirm the huge memory use.
 I've added an XML tester with your geometry in
 tests/xmltester/tests/bug334.xml
 Will take a look when i find some time.
Ticket URL: <http://trac.osgeo.org/geos/ticket/344#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
