[geos-devel] Changing path in autogen.bat
Andrea Peri 2007
aperi2007 at gmail.com
Sun Oct 10 16:16:18 EDT 2010
>Thanks. Fixed in trunk.
>Please note that makefile.vc build configuration may not be as
>up to date as the one based on GNU Autotools.
>Personally, I try to maintain the CMake-based build.
>I don't know who maintains makefile.vc files for NMAKE now.
Thx for suggestion.
After I try the build using the
.\build\msvc90\geos.sln
it generate the "geos_c.dll" but don't generate the
geos.dll.
I don't know what's the difference with geos_c.dll, but notice that all the software using geos has both.
Another try I do is try to generate with cmake a project for VC 2009 and compile with that
but the compile give some errors like this
..\src\operation\buffer\BufferBuilder.cpp(248) : error C2589: '(': token not valid to right of '::'
This seem due to some missing settings in cmake settings.
Infact if I try the compile using the available
the same file .cpp is compie without any error.
Regards,
Andrea Peri.
