[geos-devel] SIGABRT in GEOS using the C-API
    strk
    strk at keybit.net
    Wed Sep 22 13:57:21 EDT 2010
On Wed, Sep 22, 2010 at 12:13:51PM -0400, Alex Trofast wrote:
> On 09/22/2010 08:35 AM, strk wrote:
> > On Wed, Sep 22, 2010 at 08:12:39AM -0400, Alex Trofast wrote:
> > > I think you are right, after testing I noticed that GEOS compiles with
> > > -O2 by default. If you change CFLAGS/CXXFLAGS to be -O1 instead this
> > > SIGABRT does not seem to happen. Is this a bug that can or should be
> > > filed with the gcc project?
> > I guess so, assuming you're using latest stable release.
> No I'm using SVN trunk. But going back a 100 revisions or so the problem
> is the same. I haven't tried it with the stable release but I imagine
> the problem is the same.
Even better for filing a bug.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
