[geos-devel] Motion: GEOS-3.3.0 feature freeze
Charlie Savage cfis at savagexi.com
Mon Apr 18 14:03:54 EDT 2011
> On Sun, Apr 17, 2011 at 4:57 PM, Charlie Savage<cfis at savagexi.com>  wrote:
>> So I haven't done this myself, but if I go to github and click "Switch
>> Context" on the right then there is a choice to manage organizations. From
>> there you can create a new one.  What I'm not quite sure about is how to
>> then migrate your repository to the organization.
> I've set up an organization before for zoocasa and our geos-extensions
> ruby plugin so I've got the basics down. When I get some time I'll
> look into it.
>> Anyway, let me know if you want to proceed with that or not.  Once we've
>> figured that out, I can clone the repo and do some windows testing. Probably
>> won't be for a couple weeks though...in the midst of a move at the moment.
>> Yup, I'm happy to test this and fix up any issues.
> I gave a shot at building GEOS with cygwin on an XP VM I have, but my
> Windows skills have apparently degraded over the years and was unable
> to compile and was getting make errors. At any rate, I have a cygwin
> and a partial MingW environment set up for testing if anyone has any
> advice on building under Windows. At the moment I have access to the
> cygwin and MingW RubyInstaller for ruby.
GEOS built without issue last time I checked using MinGW.  I use
mingw-get versus the RubyInstaller, but that's because I'd rather have 1
mingw installation versus 3 (one for base mingw, one for msysgit one for
the ruby installer). It does take a bit of time to setup though.
Anyway, I do have it all setup so no problem testing here.  I can then
push you any changes as needed.
Thanks,
Charlie
