[geos-devel] Re: [GEOS] #469: testrunner fail
geos-trac at osgeo.org
Mon Aug 22 14:14:46 EDT 2011
Reporter: aperi2007 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.1
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by aperi2007):
I'm not sure to execute well your prescriptions.
I try:
gdb --args ./XMLTester -v --test-valid-output ./tests/testLeaksBig.xml
after execution it enter in gdb .
I type
bt,
but it report:
'no stack'
To give more information,
I report also the last part of messages from console..
Making check in tests
make[1]: Entering directory `/home/archivio/postgres/software/geos/geos-
svn/tests'
Making check in bigtest
make[2]: Entering directory `/home/archivio/postgres/software/geos/geos-
svn/tests/bigtest'
make bug234 TestSweepLineSpeed
make[3]: Entering directory `/home/archivio/postgres/software/geos/geos-
svn/tests/bigtest'
make[3]: `bug234' is up to date.
make[3]: `TestSweepLineSpeed' is up to date.
make[3]: Leaving directory `/home/archivio/postgres/software/geos/geos-
svn/tests/bigtest'
make[2]: Leaving directory `/home/archivio/postgres/software/geos/geos-
svn/tests/bigtest'
Making check in xmltester
svn/tests/xmltester'
make check-TESTS
make[3]: Warning: File `testrunner' has modification time 21 s in the
future
GNU gdb (GDB) Red Hat Enterprise Linux (7.2-48.el6)
Copyright (C) 2010 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
"/home/archivio/postgres/software/geos/geos-
svn/tests/xmltester/XMLTester": not in executable format: File format not
recognized
(gdb) bt
No stack.
(gdb)
Ticket URL: <http://trac.osgeo.org/geos/ticket/469#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
