[geos-devel] Re: [GEOS] #469: testrunner fail
geos-trac at osgeo.org
Mon Aug 22 14:21:38 EDT 2011
Reporter: aperi2007 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.1
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by aperi2007):
I have obtain some result from gdb.
after an execution it report this
I'm not sure if it is really useful :)
make check-TESTS
make[3]: Entering directory `/home/archivio/postgres/software/geos/geos-
svn/tests/unit'
GEOS Test Suite Application
capi::GEOSBuffer: ....................
capi::GEOSContains: ...
capi::GEOSCoordSeq: ......lt-geos_unit: GeometryComponentFilter.cpp:35:
virtual void geos::geom::GeometryComponentFilter::filter_ro(const
geos::geom::Geometry*): Assertion `0' failed.
/bin/sh: line 5: 23596 Aborted (core dumped) ${dir}$tst
FAIL: geos_unit
1 of 1 test failed
make[3]: *** [check-TESTS] Error 1
make[3]: Leaving directory `/home/archivio/postgres/software/geos/geos-
svn/tests/unit'
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `/home/archivio/postgres/software/geos/geos-
svn/tests/unit'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/home/archivio/postgres/software/geos/geos-
svn/tests'
make: *** [check-recursive] Error 1
[postgres at artu geos-svn]$
Ticket URL: <http://trac.osgeo.org/geos/ticket/469#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
