[geos-devel] distance
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 26 14:46:27 EDT 2011
Tomas,
If you dig into one of the representations, such as "well known text as HTML"
you can see the units. In the WKT it is:
PROJCS["POSGAR 94 / Argentina 6",
GEOGCS["POSGAR 94",
DATUM["Posiciones_Geodesicas_Argentinas_1994",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6694"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4694"]],
UNIT["metre",1, <<<<<<<< ***************** UNITS *****************
AUTHORITY["EPSG","9001"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",-90],
PARAMETER["central_meridian",-57],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",6500000],
PARAMETER["false_northing",0],
AUTHORITY["EPSG","22186"],
AXIS["Y",EAST],
AXIS["X",NORTH]]
On Fri, Aug 26, 2011 at 11:42 AM, Tomas Neme <lacrymology at gmail.com> wrote:
>> Hi Tomas,
>> All the GEOS operations are done in a unitless Cartesian space.
>> Distance is unitless. For example, the distance between a point at (0,
>> 0) and (1, 1) is sqrt(2). 22186 has units of meters, right? As long as
>> your distances are in meters (1000 in your case), you'll be fine.
> I thought so, but.. how do I know this?
> http://www.spatialreference.org/ref/epsg/22186/
> this is all the info I could get on 22186, it doesn't say anything
> about units. we use meters in AR, so I guess you must be right, but
> not the point.. finding info on this subject is very hard =/
> "The whole of Japan is pure invention. There is no such country, there
> are no such people" --Oscar Wilde
> |_|0|_|
> |_|_|0|
> |0|0|0|
> (\__/)
> (='.'=)This is Bunny. Copy and paste bunny
> (")_(") to help him gain world domination.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
and watch the world go round - Rush | Geospatial Software Developer
