[geos-devel] Re: [GEOS] #501: Snap operation: wrong snapping
GEOS geos-trac at osgeo.org
Fri Dec 16 06:13:27 EST 2011
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  GEOS Future
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:  jtsfail
Comment(by strk):
 I've been thinking that vertex snapping could maybe be performed against
 the _farest_ point within tolerance rather than the closest one. And the
 fartest from segment startpoint. Doing so should ensure that later segment
 snapping would not introduce overstrikes.
 Surely needs more thinking and presentation of a set of cases
Ticket URL: <http://trac.osgeo.org/geos/ticket/501#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
