[geos-devel] Re: [GEOS] #501: Snap operation: wrong snapping
GEOS geos-trac at osgeo.org
Fri Dec 16 07:42:12 EST 2011
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  GEOS Future
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:  jtsfail
Comment(by aperi2007):
 Please,
 I guess this other case is really more understandable :)
 ( a little difference between the vertex of the lines to help to
 understand if the vertex choose is from line1 or line2 )
 ST_Snap(
         'LINESTRING(0 0, 10 0)',
          LINESTRING(0.1 0, 9.1 0, 10.01 0, 10.9 0),
          2
 ) = LINESTRING(0.1 0, 10.9 0, 10.01 0, 9.1 0)
 Please, can you repeat your debug output with this ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/501#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
