[geos-devel] RE: GEOS errors from PostGIS
James.Sewell at lisasoft.com
Thu Jan 20 18:31:21 EST 2011
Right,
Once again thanks for the help on this.
Attached is a zip with the two geometries that I am having problems unioning (2.7mb I'll up to an FTP if it doesn't get through), when testing I have them both in a table called alw as separate rows. I realise that the linework is very dirty, but it is what we have to work with in this case.
The following commands will cause errors. If I don't include the snaptogrid there will not be an error in *this* case, but if I were to run the whole process with no snap there would be an error at some stage.
Any help appreciated! I am working on getting a smaller dataset which exhibits the problem.
CREATE TABLE alwunionxx AS
SELECT
st_union(st_collect(st_snaptogrid(the_geom,10E-8)), ST_SetSRID('LINESTRINGEMPTY', 4283))
AS the_geom
FROM alw;
NOTICE: TopologyException: found non-noded intersection between LINESTRING (146.593 -37.2263, 146.593 -37.2263) and LINESTRING (146.593 -37.2263, 146.593 -37.2263) at 146.593 -37.2263
ERROR: GEOS union() threw an error!
SELECT
st_union(st_snaptogrid(the_geom,10E-8))
AS the_geom
FROM alw;
Cheers,
James Sewell
Developer
LISAsoft
Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
Level 9, 601 Bourke St, Melbourne Vic 3000
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
-----Original Message-----
From: geos-devel-bounces at lists.osgeo.org [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of strk
Sent: Tuesday, 18 January 2011 2:48 AM
To: GEOS Development List
Subject: Re: [geos-devel] RE: GEOS errors from PostGIS
On Mon, Jan 17, 2011 at 11:05:42AM +1030, James.Sewell at lisasoft.com wrote:
> The latest daily doesn't help the problem so I've reverted to 3.2.2 and performed some more testing.
> I have a dataset where:
> ST_Union(the_geom, ST_SetSRID('LINESTRING EMPTY', 4283))
> Fails, yet
> ST_Union(the_geom).
> Works. There are other datasets which fail on both versions, and I have no doubt I can find one which works in the reverse manner.
The latter uses CascadedUnion (the one UnaryUnion uses too).
The former uses normal union (non-cascaded).
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
Type: application/x-zip-compressed
Desc: errors.zip
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20110121/f87c2be4/errors-0001.bin
