[geos-devel] RE: GEOS errors from PostGIS
Martin Davis
mtnclimb at telus.net
Mon Jan 24 00:53:17 EST 2011
FWIW, I ran this data through JTS 1.11 using both union(geom, geom) and
union(geom), and both operations completed without errors.
Not sure what this says about the GEOS issue - other than more debugging
required...!
On 1/20/2011 3:31 PM, James.Sewell at lisasoft.com wrote:
> Right,
> Once again thanks for the help on this.
> Attached is a zip with the two geometries that I am having problems unioning (2.7mb I'll up to an FTP if it doesn't get through), when testing I have them both in a table called alw as separate rows. I realise that the linework is very dirty, but it is what we have to work with in this case.
> The following commands will cause errors. If I don't include the snaptogrid there will not be an error in *this* case, but if I were to run the whole process with no snap there would be an error at some stage.
> Any help appreciated! I am working on getting a smaller dataset which exhibits the problem.
> CREATE TABLE alwunionxx AS
> SELECT
> st_union(st_collect(st_snaptogrid(the_geom,10E-8)), ST_SetSRID('LINESTRINGEMPTY', 4283))
> AS the_geom
> FROM alw;
> NOTICE: TopologyException: found non-noded intersection between LINESTRING (146.593 -37.2263, 146.593 -37.2263) and LINESTRING (146.593 -37.2263, 146.593 -37.2263) at 146.593 -37.2263
> ERROR: GEOS union() threw an error!
> SELECT
> st_union(st_snaptogrid(the_geom,10E-8))
> AS the_geom
> FROM alw;
> Cheers,
> James Sewell
> Developer
> LISAsoft
> Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
> Level 9, 601 Bourke St, Melbourne Vic 3000
> LISAsoft is part of the A2end Group of Companies
> http://www.ardec.com.au
> http://www.lisasoft.com
> http://www.terrapages.com
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of strk
> Sent: Tuesday, 18 January 2011 2:48 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] RE: GEOS errors from PostGIS
> On Mon, Jan 17, 2011 at 11:05:42AM +1030, James.Sewell at lisasoft.com wrote:
>> The latest daily doesn't help the problem so I've reverted to 3.2.2 and performed some more testing.
>> I have a dataset where:
>> ST_Union(the_geom, ST_SetSRID('LINESTRING EMPTY', 4283))
>> Fails, yet
>> ST_Union(the_geom).
>> Works. There are other datasets which fail on both versions, and I have no doubt I can find one which works in the reverse manner.
> The latter uses CascadedUnion (the one UnaryUnion uses too).
> The former uses normal union (non-cascaded).
> --strk;
> () Free GIS& Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 10.0.1191 / Virus Database: 1435/3392 - Release Date: 01/20/11
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20110123/1acbd2da/attachment.html
