[geos-devel] Re: [GEOS] #458: Polygonizer robustness failure
geos-trac at osgeo.org
Thu Jul 14 08:43:49 EDT 2011
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.1
Component: Default | Version: 3.3.0
Severity: Unassigned | Keywords:
Description changed by strk:
Old description:
> A simple multiline containing 3 linestrings of 2,5 and 6 vertices, all
> sharing the same endpoints (2 nodes in total in the topology)
> fail to be polygonized in floating precision, while successfully
> polygonize as 2 rings with a precision of 1e-11.
> See http://trac.osgeo.org/postgis/ticket/1115 for original report.
> In the geometry with 5 vertices, distance between first and second vertex
> and between forth and fifth vertex is 2.3283064365387e-10.
> The polygonizer returns _no_ rings.
> Dropping one of the close-by vertices (not on the topology node)
> makes the polygonizer return _1_ ring.
> Dropping both makes it succeed in returning _2_ rings as it should.
> Simplified MULTILINESTRING input follows:
> 010500000003000000010200000002000000555C8F42354A3A41A4703D6A1E445241CCCCCC0C474A3A415C8FC2851E445241010200000005000000555C8F42354A3A41A4703D6A1E445241545C8F42354A3A41A4703D6A1E445241409B06043D4A3A415860C1CC1C445241CDCCCC0C474A3A415C8FC2851E445241CCCCCC0C474A3A415C8FC2851E445241010200000006000000CCCCCC0C474A3A415C8FC2851E445241C4F5289C4B4A3A415C8FC2C52B445241B533D71C964A3A418EAD7CBD1A4452412085EB91284A3A417A14AE2719445241285C8F42354A3A41A4703D6A1E445241555C8F42354A3A41A4703D6A1E445241
New description:
Ticket URL: <http://trac.osgeo.org/geos/ticket/458#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
