[geos-devel] Re: [GEOS] #458: Polygonizer robustness failure
geos-trac at osgeo.org
Thu Jul 14 12:01:50 EDT 2011
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.3.1
Component: Default | Version: 3.3.0
Severity: Unassigned | Resolution: invalid
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => invalid
Comment:
It seems that the input is still not properly noded.
In particular there's a linear intersection between the line with 5
vertices and the one with 6. Passing the geometry under unaryunion turn it
to a 4 lines geometry, and that one successfully polygonizes.
Ticket URL: <http://trac.osgeo.org/geos/ticket/458#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
