[geos-devel] [GEOS] #439: St9bad_alloc GEOS throws intersect error!
geos-trac at osgeo.org
Wed May 11 10:32:27 EDT 2011
Reporter: marquis103 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.2.0
Severity: Unassigned | Keywords: ST9bad_alloc
I have a huge repository of geospatial data (17M) data objects. I'm
attempting to build a view of the data by United States Command area. I
have a shapefile built that divides countries up by polygon and command
area. I can build all command areas except for northcom (United States,
Puerto Rico, Canada, Mexico). The rest of the entire world builds great.
I can't attach the geometries because I can't see which ones are causing
the errors.
I just always get:
NOTICE: St9bad_alloc
CONTEXT: SQL statement "CREATE TABLE products_by_location_mv AS SELECT *
FROM vw_products_by_location"
PL/pgSQL function "create_matview" line 17 at EXECUTE statement
ERROR: GEOS intersects() threw an error!
but no real documentation on an error to see what the case may be. All
the polygons return valid. Is there anything I can do to problem get an
idea of what geometries are causing the errors?
I'm on Windows 64 bit 2008
32GB Memory
Postgres 8.3
Postgis 1.5.2
GEOS 3.2
Ticket URL: <http://trac.osgeo.org/geos/ticket/439>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
