[geos-devel] Re: [GEOS] #439: St9bad_alloc GEOS throws intersect error!
GEOS geos-trac at osgeo.org
Wed May 11 11:00:31 EDT 2011
 Reporter:  marquis103  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:  ST9bad_alloc
Comment(by strk):
 GEOS-3.2.2 was released to fix a memory leak, see if it still happens
 there.
 Even better if you try with a development snapshot as of today, to become
 3.3.0 soon.
Ticket URL: <http://trac.osgeo.org/geos/ticket/439#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
