[geos-devel] Second beta for ffi-geos extension now available
Sean Gillies sean.gillies at gmail.com
Thu May 12 11:42:20 EDT 2011
On Thu, May 12, 2011 at 9:28 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Thu, May 12, 2011 at 11:16:19AM -0400, J Smith wrote:
>> On Thu, May 12, 2011 at 2:19 AM, Sandro Santilli <strk at keybit.net> wrote:
>> > Right. In the PHP binding I've made a single function taking an associative
>> > array for all the parameters (building a GEOSBufferParameter object).
>> Yeah, I noticed that and decided to follow suit. I'd like the two to
>> be reasonably close together in terms of their APIs and conventions
>> aside from the usual language quirks and conventions.
> Speaking of which... how did you deal with prepared geoms ?
> I didnt' make any use of those from the PHP binding. Dunno if I want
> them to be transparent or explicit.
FWIW, Shapely has a prep() function that prepares a geometry. The
result has a subset of the normal geometric object methods.
http://gispython.org/shapely/docs/1.2/manual.html#prepared-geometry-operations
Sean
