[geos-devel] Re: cmake maintainance and distribution
Sandro Santilli
strk at keybit.net
Tue May 17 16:46:54 EDT 2011
On Tue, May 17, 2011 at 07:47:01PM +0100, Mateusz Loskot wrote:
> On 17/05/11 17:48, Sandro Santilli wrote:
> > It was noted in ticket [441] that CMake build scripts
> > are not being distributed.
> > Now, before distributing them I'd like to know if someone
> > is willing to maintain them, and in that case I'd ask this
> > someone to proceed at fixing the distribution bug as well.
> > So, anyone willing to maintain it ?
> > [441] http://trac.osgeo.org/geos/ticket/441
> Sandro,
> I aim to maintain CMake configuration.
> Is this enough to fix 441 for now?
Fixed in r3369.
Could you now fix the isfinite vs std::isfinite issue for cmake ?
src/algorithm/RobustDeterminant.cpp: In static member function 'static int geos::algorithm::RobustDeterminant::signOfDet2x2(double, double, double, double)':
src/algorithm/RobustDeterminant.cpp:48: error: 'isfinite' was not declared in this scope
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
