[geos-devel] Re: [GEOS] #276: "make check" failed at geos_unit on
mingw
geos-trac at osgeo.org
Wed May 25 15:38:21 EDT 2011
#276: "make check" failed at geos_unit on mingw
Reporter: sanak | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.3.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution: fixed
Keywords: mingw |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
This works for me, but my make check tests are failing on 4 tests. I'll
put as separate ticket.
Ticket URL: <http://trac.osgeo.org/geos/ticket/276#comment:8>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
