[geos-devel] Re: [GEOS] #299:
geos::geom::CoordinateArraySequenceFactory unit test failing
geos-trac at osgeo.org
Sat May 28 13:05:28 EDT 2011
#299: geos::geom::CoordinateArraySequenceFactory unit test failing
Reporter: pramsey | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: Unit Tests | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: mac,macosx,osx |
Comment(by strk):
You mentioned on the mailing list that this bug is fixed by using GCC-4.0,
right ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:21>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
