[geos-devel] Re: [GEOS] #299: geos::geom::CoordinateArraySequenceFactory unit test failing
GEOS geos-trac at osgeo.org
Sat May 28 13:26:20 EDT 2011
 Reporter:  pramsey         |        Owner:  geos-devel@…
     Type:  defect          |       Status:  new
 Priority:  major           |    Milestone:  3.3.0
Component:  Unit Tests      |      Version:  svn-trunk
 Severity:  Unassigned      |   Resolution:
 Keywords:  mac,macosx,osx  |
Comment(by kyngchaos):
 As a workaround.  I still need to try it with QGIS compiled with GCC 4.2.
 Everything else (GDAL, MapServer, ...) uses the C API so they shouldn't
 have any problems with C++ version issues.
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:22>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
