[geos-devel] Fix to enable ruby bindings with ruby 1.9.3 (#5)
strk
strk at keybit.net
Thu Nov 24 13:08:03 EST 2011
Can any Ruby/GEOS developer take a look at this ?
--strk;
----- Forwarded message from Kashif Rasul <reply+i-2343458-1cdc8d98222d899aaee0dec2f2f850335f5cccc0-289678 at reply.github.com> -----
Date: Thu, 24 Nov 2011 09:07:04 -0800
To: strk <strk at keybit.net>
Subject: [geos] Fix to enable ruby bindings with ruby 1.9.3 (#5)
List-Id: <geos.strk.github.com>
Tested via ruby 1.9.3.
Regenerated the cpp file with swig 2.0.4.
TODO: test with ruby 1.8.x and rbx?
You can merge this Pull Request by running:
git pull https://github.com/kashif/geos master
Or you can view, comment on it, or merge it online at:
https://github.com/strk/geos/pull/5
-- Commit Summary --
* Fix to get swig/ruby compiling for ruby 1.9
-- File Changes --
M macros/ruby.m4 (9)
M swig/ruby/Makefile.am (2)
M swig/ruby/geos_wrap.cxx (6472)
M swig/ruby/ruby.i (2)
-- Patch Links --
https://github.com/strk/geos/pull/5.patch
https://github.com/strk/geos/pull/5.diff
Reply to this email directly or view it on GitHub:
----- End forwarded message -----
