[geos-devel] [GEOS] #495: Empty return from buffer
geos-trac at osgeo.org
Mon Nov 28 04:31:31 EST 2011
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.2
Component: Default | Version: 3.3.0
Severity: Unassigned | Keywords:
The attached test triggers a bug which makes GEOS return an empty buffer
(unexpected). Worked fine in 3.2.0
Ticket URL: <http://trac.osgeo.org/geos/ticket/495>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
