[geos-devel] [GEOS] #496: Expose a GEOSNode interface in the C-API
GEOS geos-trac at osgeo.org
Wed Nov 30 04:20:24 EST 2011
 Reporter:  strk         |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  3.4.0
Component:  Default      |     Version:  svn-trunk
 Severity:  Unassigned   |    Keywords:
 Such function should be used to fully node input linework.
 It should take an optional "precision" parameter to perform snapping of
 input vertices and intersection points to a given grid. Such functionality
 should be very helpful in improving robustness and predictability for
 clients.
Ticket URL: <http://trac.osgeo.org/geos/ticket/496>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
