[geos-devel] Re: [GEOS] #489: CMAKE_CXX_FLAGS overrides -std=gnu++0x
geos-trac at osgeo.org
Mon Oct 17 18:58:47 EDT 2011
Reporter: jyasskin | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.3.2
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by jyasskin):
Of course, you intended to override _gnu_++0x and change it to c++0x, but
-ansi means -std=c++98 (http://gcc.gnu.org/onlinedocs/gcc-4.6.1/gcc/C
-Dialect-Options.html), so it overrides -std=c++0x too.
Ticket URL: <http://trac.osgeo.org/geos/ticket/489#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
