[geos-devel] [GEOS] #491: Fix C++11 build by avoiding
std::pair<auto_ptr>
geos-trac at osgeo.org
Mon Oct 17 19:22:11 EDT 2011
#491: Fix C++11 build by avoiding std::pair<auto_ptr>
Reporter: jyasskin | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.2
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
The new C++11 standard disallows using std::auto_ptr as a member of
std::pair: http://lwg.github.com/issues/lwg-closed.html#2068. This patch
defines a very simple struct to replace the GeomPtrPair typedef to avoid
this issue.
Ticket URL: <http://trac.osgeo.org/geos/ticket/491>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
