[geos-devel] Re: [GEOS] #527: Union and UnaryUnion both fail at
correctly node input lines
geos-trac at osgeo.org
Mon Apr 2 05:46:02 EDT 2012
#527: Union and UnaryUnion both fail at correctly node input lines
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.4
Component: Default | Version: 3.3.3
Severity: Unassigned | Keywords:
Comment(by strk):
Uff, ST_IsSimple isn't a good check when it comes to _closed_ lines, in
that they have no bounday so the node would be considered as an
interior/interior intersection, like here:
MULTILINESTRING((0 0, 10 0, 10 10, 0 0), (0 0, -10 0, -10 -10, 0 0))
The boundary node rule is really getting in my way.
@mbdavis : how can I check for correct noding ? And is Polygonizer happy
with noding which involves closed lines ?
/me goes on to try again the polygonizer call with more closed lines.
Ticket URL: <http://trac.osgeo.org/geos/ticket/527#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
