[geos-devel] Re: [GEOS] #527: Union and UnaryUnion both fail at
correctly node input lines
geos-trac at osgeo.org
Tue Apr 3 06:52:19 EDT 2012
#527: Union and UnaryUnion both fail at correctly node input lines
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.4
Component: Default | Version: 3.3.3
Severity: Unassigned | Keywords:
Comment(by strk):
For the record: the IteratedNoder succeeds in noding the above input with
2 iterations, but the overlay operation isn't using the noding classes at
all if I'm not mistaken.
Ticket URL: <http://trac.osgeo.org/geos/ticket/527#comment:8>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
