[geos-devel] Re: [GEOS] #527: Union and UnaryUnion both fail at correctly node input lines
GEOS geos-trac at osgeo.org
Tue Apr 3 08:41:10 EDT 2012
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.4
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 I've to correct myself, it takes 5 iterations to correctly node the above!
 Iteration1: # nodes created: 3
 Iteration2: # nodes created: 3
 Iteration3: # nodes created: 5
 Iteration4: # nodes created: 5
 Iteration5: # nodes created: 5
 Iteration6: # nodes created: 0
 Since IteratedNoder returns 19 output segments, many of which being
 duplicates, I'm not sure it's doing its work the way it's meant to.
Ticket URL: <http://trac.osgeo.org/geos/ticket/527#comment:9>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
