[geos-devel] Re: [GEOS] #527: Union and UnaryUnion both fail at correctly node input lines
GEOS geos-trac at osgeo.org
Tue Apr 10 11:07:00 EDT 2012
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.4
Component:  Default     |     Version:  3.3.3
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 With r3606 in 3.3 branch and r3607 in trunk the binary union is enhanced
 to always re-union (self union) the results of operations to which common
 bits are re-added. Doing so fixes this case and the PostGIS case
 http://trac.osgeo.org/postgis/ticket/1735
 Unary union itself is still not fixed in that it takes a different path
 (doesn't use BinaryOp).
 May be worth updating it to use BinaryOp as well, but must be aware of
 possible infinite loops as one would be calling the other...
Ticket URL: <http://trac.osgeo.org/geos/ticket/527#comment:10>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
