[geos-devel] Re: [GEOS] #527: Union and UnaryUnion both fail at
correctly node input lines
geos-trac at osgeo.org
Tue Apr 10 11:59:05 EDT 2012
#527: Union and UnaryUnion both fail at correctly node input lines
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.3.4
Component: Default | Version: 3.3.3
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
r3610 / r3611 add a testcase for this (3.3 / trunk)
Ticket URL: <http://trac.osgeo.org/geos/ticket/527#comment:12>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
