[geos-devel] [GEOS] #582: GEOSGetCentroid seg faults on certain MultiPolygons
GEOS geos-trac at osgeo.org
Sat Aug 25 23:30:54 PDT 2012
 Reporter:  dazuma      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.3.5
Component:  Default     |     Version:  3.3.4
 Severity:  Unassigned  |    Keywords:
 Consider the following MultiPolygon:
 MULTIPOLYGON(EMPTY, ((0 1, 1 1, 1 0, 0 0, 0 1)))
 I'm not completely clear on whether this should be considered a valid
 MultiPolygon. Most calls handle it fine. However, calling
 GEOSGetCentroid_r on it results in a segmentation fault.
 The seg fault seems to happen when the MultiPolygon contains at least one
 EMPTY polygon *and* at least one non-empty polygon. MultiPolygons
 containing only EMPTYs or only non-emptys work fine.
Ticket URL: <http://trac.osgeo.org/geos/ticket/582>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
