[geos-devel] [GEOS] #605: Crash from GEOSBuffer: RightmostEdgeFinder.cpp: Assertion `checked>0` failed
geos-trac at osgeo.org
Tue Dec 4 07:32:43 PST 2012
failed
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.3.7
Component: Default | Version: 3.3.6
Severity: Critical | Keywords:
Comment(by strk):
Another hint: the problem in turn seems to originate in non-noded input
being feeded to PlanarGraph. Pre-noding the input also seems to fix the
case (in PostGIS: ST_Buffer(ST_Node(...), 1000))
Ticket URL: <http://trac.osgeo.org/geos/ticket/605#comment:12>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
