[geos-devel] [GEOS] #605: Crash from GEOSBuffer: RightmostEdgeFinder.cpp: Assertion `checked>0` failed
geos-trac at osgeo.org
Tue Dec 4 08:16:53 PST 2012
failed
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.3.7
Component: Default | Version: 3.3.6
Severity: Critical | Keywords:
Comment(by strk):
Alright so I think it is a perfectly legit case of a dangling edge in the
topology.
If the node of degree 1 (the unconnected end) of the dangling edge is the
_end_ vertex of the edge, eventually the BufferSubgraph create function
will start from there and produce a subgraph of that edge _only_, and that
edge will be backward. And in turn that'll take us to the exception.
Ticket URL: <http://trac.osgeo.org/geos/ticket/605#comment:13>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
