[geos-devel] Re: [GEOS] #299:
geos::geom::CoordinateArraySequenceFactory unit
test failing on Bad Apple
geos-trac at osgeo.org
Sun Feb 12 10:01:05 EST 2012
#299: geos::geom::CoordinateArraySequenceFactory unit test failing on Bad Apple
Reporter: pramsey | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: GEOS Future
Component: Unit Tests | Version: svn-trunk
Severity: Unassigned | Resolution: fixed
Keywords: mac,macosx,osx |
Changes (by 2sin18):
* status: reopened => closed
* resolution: => fixed
Comment:
It is a GEOS bug, I fix it using following steps:
1 add a dealloc method implementation for
geos::operation::releate::RelateComputer
2 add missing includes in geos::geom::util::SineStarFactory
implementation:
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/LinearRing.h>
It works good with GEOS 3.3.0 for Mac OSX 10.7.
I do not know how to commit a patch, somebody could make one, thanks.
BTW GEOS should do more code review.
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:30>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
