[geos-devel] GEOS-3.3.2 tagged, ready to release
Sandro Santilli strk at keybit.net
Thu Jan 5 11:15:33 EST 2012
I've just tagged 3.3.2.
Changes since 3.3.1:
- Bug fixes / improvements
    - Fix CMAKE_CXX_FLAGS overriding -std=gnu++0x (#489)
    - Missing versions update in CMake configuration (#490)
    - Fix noding of self-intersecting lines through UnaryUnion (#482)
    - Fix handling of collapsed edges skipping in BufferOp (#494)
    - Print up to 18 digits of precision for TopologyException points
    - Fix noding with reduced precision in Buffer operation (#473)
    - Fix HotPixel original point invalidation (#498)
    - Fix CascadedPolygonUnion to discard non-polygonal components (#499)
    - Improve buffer robustness by reverting to non-snaprounding noder (#495)
    - Fix C++11 build by avoiding std::pair<auto_ptr> (#491)
    - Add --clibs to geos-config and GEOS_C_LIBS to geos.m4 (#497)
    - Apply shoelace formula for area calculation (#485)
    - Fix default initialization issue for clang (#500)
    - Improve overlay robustness by fixing areal validity on snapping (#488)
Paul: you seem to be the only one allowed to upload to osgeo.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
