[geos-devel] Re: GEOS-3.3.2 tagged, ready to release
Paul Ramsey pramsey at cleverelephant.ca
Thu Jan 5 14:16:23 EST 2012
Released, thanks so much!
P.
On Thu, Jan 5, 2012 at 8:15 AM, Sandro Santilli <strk at keybit.net> wrote:
> I've just tagged 3.3.2.
> Changes since 3.3.1:
> - Bug fixes / improvements
>    - Fix CMAKE_CXX_FLAGS overriding -std=gnu++0x (#489)
>    - Missing versions update in CMake configuration (#490)
>    - Fix noding of self-intersecting lines through UnaryUnion (#482)
>    - Fix handling of collapsed edges skipping in BufferOp (#494)
>    - Print up to 18 digits of precision for TopologyException points
>    - Fix noding with reduced precision in Buffer operation (#473)
>    - Fix HotPixel original point invalidation (#498)
>    - Fix CascadedPolygonUnion to discard non-polygonal components (#499)
>    - Improve buffer robustness by reverting to non-snaprounding noder (#495)
>    - Fix C++11 build by avoiding std::pair<auto_ptr> (#491)
>    - Add --clibs to geos-config and GEOS_C_LIBS to geos.m4 (#497)
>    - Apply shoelace formula for area calculation (#485)
>    - Fix default initialization issue for clang (#500)
>    - Improve overlay robustness by fixing areal validity on snapping (#488)
> Paul: you seem to be the only one allowed to upload to osgeo.
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
