[geos-devel] Call for test of the 3.3 branch
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jan 6 15:30:14 EST 2012
I'm trying to compile 3.3.2 on Windows (MSVC 2008/9.0) and getting the
following error:
BufferOp.cpp
operation\buffer\BufferOp.cpp(97) : error C2668: 'log' : ambiguous call
to overloaded fun
tion
C:\Program Files\Microsoft Visual Studio
9.0\VC\INCLUDE\math.h(121): could be 'do
ble log(double)'
9.0\VC\INCLUDE\math.h(519): or 'fl
at log(float)'
9.0\VC\INCLUDE\math.h(567): or 'lo
g double log(long double)'
while trying to match the argument list '(int)'
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
9.0\VC\BIN\cl.EXE"'
: return code '0x2'
Stop.
9.0\VC\BIN\nmake.EX
"' : return code '0x2'
Stop.
Anyone have any ideas?
-jeff
On 11-12-09 6:59 AM, Sandro Santilli wrote:
> I've spent the last couple of weeks hunting buffer robustness
> issues and fixing few more bugs in the 3.3 branch.
> I'd release a 3.3.2 shortly with the fixes.
> Biggest change is in Buffer operation, specifically in handling
> of reduced precision buffering in case of a topology exception
> raised with the full-precision attempt.
> As I also applied a few patch supposedly fixing build on different
> architectures I'd like to call for tests of the branch prior to
> closing up the release.
> Here's a list of bugfixes:
> http://trac.osgeo.org/geos/query?status=closed&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&milestone=3.3.2
> Still open issues (not sure they'll make it into 3.3.2):
> http://trac.osgeo.org/geos/query?status=assigned&status=new&status=reopened&order=priority&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&milestone=3.3.2
> Thanks for testing.
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
