[geos-devel] build error...
Sandro Santilli
strk at keybit.net
Wed Jun 6 06:17:24 PDT 2012
On Wed, Jun 06, 2012 at 08:52:34AM -0400, David Burken wrote:
> Thanks Sandro!
> After fixing that there's one more (Fedora 17 gcc version 4.7.0 )
> CMakeFiles/geos_unit.dir/capi/GEOSConvexHullTest.cpp.o:(.bss+0x0):
> multiple definition of `tut::test_capigeoscontains_group'
> CMakeFiles/geos_unit.dir/capi/GEOSContainsTest.cpp.o:(.bss+0x0):
> first defined here
> Commenting one out fixes...
Could you please file a ticket for this ?
> Here's a cmake macro you could use. You can see this example at:
> http://www.cmake.org/cmake/help/v2.8.8/cmake.html
What's wrong with using tools/svn_repo_revision.sh ?
I build from git so the cmake way won't work.
On the other hand, I don't build with cmake so this is a non-issue.
In any case a ticket for this would be useful.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
