[geos-devel] build error...
David Burken
dburken at comcast.net
Wed Jun 6 06:44:17 PDT 2012
On 06/06/2012 09:17 AM, Sandro Santilli wrote:
> On Wed, Jun 06, 2012 at 08:52:34AM -0400, David Burken wrote:
>> Thanks Sandro!
>> After fixing that there's one more (Fedora 17 gcc version 4.7.0 )
>> CMakeFiles/geos_unit.dir/capi/GEOSConvexHullTest.cpp.o:(.bss+0x0):
>> multiple definition of `tut::test_capigeoscontains_group'
>> CMakeFiles/geos_unit.dir/capi/GEOSContainsTest.cpp.o:(.bss+0x0):
>> first defined here
>> Commenting one out fixes...
> Could you please file a ticket for this ?
http://trac.osgeo.org/geos/ticket/555
>> Here's a cmake macro you could use. You can see this example at:
>> http://www.cmake.org/cmake/help/v2.8.8/cmake.html
> What's wrong with using tools/svn_repo_revision.sh ?
It's fine with me. I did know there was a tool to generate. I was just
letting you know.
> I build from git so the cmake way won't work.
> On the other hand, I don't build with cmake so this is a non-issue.
> In any case a ticket for this would be useful.
http://trac.osgeo.org/geos/ticket/556
Thanks for the help...
Dave
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
