[geos-devel] [GEOS] #554: Artifacts and limitations of bufferLineSingleSided
geos-trac at osgeo.org
Fri Jun 22 05:35:29 PDT 2012
Reporter: ylan | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by strk):
You probably forgot to run ./configure again after updating (geos_c.h is
generated from geos_c.h.in at configure time and contains the definition
of GEOSInterruptCallback that line 118 is referencing)
Ticket URL: <http://trac.osgeo.org/geos/ticket/554#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
