[geos-devel] [GEOS] #554: Artifacts and limitations of bufferLineSingleSided
GEOS geos-trac at osgeo.org
Fri Jun 22 06:33:47 PDT 2012
 Reporter:  ylan        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by ylan):
 You're right. I forgot to do that. Thanks for the hint.
 As for the single side buffering: the problem still exists in r3675.
Ticket URL: <http://trac.osgeo.org/geos/ticket/554#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
