[geos-devel] [GEOS] #516: platform.h doesn't work right for mingw64
geos-trac at osgeo.org
Wed Mar 7 00:53:35 EST 2012
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.3
Component: Default | Version: 3.3.2
Severity: Unassigned | Keywords:
IT may not work right for ming32 either which would explain the numerous
errors.
Regarding what the spatialite guy did to hack the platform.h to hardcode
the right answer:
typedef long long int int64;
He described in
http://www.gaia-gis.it/spatialite-3.0.0-BETA/mingw64_how_to.html#libgeos
When rebuilding my mingw 64 to make sure I didn't miss anything, I left
out this step to see what would happen. It compiled but I ended up with
about 30 errors on make check. Putting it back got me back to the single
harmless IND failure.
float-store was on in both situations.
Ticket URL: <http://trac.osgeo.org/geos/ticket/516>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
