Greetings all, Using the CAPI if you have a geometry, you set its' SRID, then perform for example a buffer on this geometry, the result geometry does not get set with the input geometries SRID and you have to set it again. Is this the way it's intended to work or should the result keep the SRID? Thanks, -- Alex http://bit.ly/geodb
