[geos-devel] Modifying vertices without copying ?
Sandro Santilli
strk at keybit.net
Thu Mar 15 06:39:59 EDT 2012
Look at coordinate filters ? --strk;
On Thu, Mar 15, 2012 at 11:38:14AM +0100, Oyvind Idland wrote:
> I do use the C++ API, and have been taking a look at
> geos::geom::util::GeometryTransformer.
> geos::geom::util::GeometryTransformer is based on copying aswell, or, at
> least I can't see
> an way to change that behaviour ?
> -- Oyvind
> On Thu, Mar 15, 2012 at 11:02 AM, Sandro Santilli <strk at keybit.net> wrote:
> > On Thu, Mar 15, 2012 at 10:45:31AM +0100, Oyvind Idland wrote:
> > > is it possible in some way to modify vertices on geometries, without
> > making
> > > copies ?
> > It should be possible with the C++ api.
> > Check out coordinate transformation classes.
> > Probably not very well tested.
> > --strk;
> > ,------o-.
> > | __/ | Delivering high quality PostGIS 2.0 !
> > | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> > `-o------'
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geos-devel
,------o-.
`-o------'
