[geos-devel] Modifying vertices without copying ?
Oyvind Idland
oyvind.idland at gmail.com
Thu Mar 15 08:04:18 EDT 2012
Excellent, works like a charm ! :)
Thanks.
-- Oyvind
On Thu, Mar 15, 2012 at 11:39 AM, Sandro Santilli <strk at keybit.net> wrote:
> Look at coordinate filters ? --strk;
> On Thu, Mar 15, 2012 at 11:38:14AM +0100, Oyvind Idland wrote:
> > I do use the C++ API, and have been taking a look at
> > geos::geom::util::GeometryTransformer.
> > geos::geom::util::GeometryTransformer is based on copying aswell, or, at
> > least I can't see
> > an way to change that behaviour ?
> > -- Oyvind
> > On Thu, Mar 15, 2012 at 11:02 AM, Sandro Santilli <strk at keybit.net>
> wrote:
> > > On Thu, Mar 15, 2012 at 10:45:31AM +0100, Oyvind Idland wrote:
> > > > is it possible in some way to modify vertices on geometries, without
> > > making
> > > > copies ?
> > > It should be possible with the C++ api.
> > > Check out coordinate transformation classes.
> > > Probably not very well tested.
> > > --strk;
> > > ,------o-.
> > > | __/ | Delivering high quality PostGIS 2.0 !
> > > | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> > > `-o------'
> > > _______________________________________________
> > > geos-devel mailing list
> > > geos-devel at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/geos-devel
> ,------o-.
> `-o------'
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20120315/b24f5839/attachment.html
