[geos-devel] [GEOS] #523: SymDifference between two valid
geometries return an _invalid_ geometry
geos-trac at osgeo.org
Fri Mar 30 05:47:58 EDT 2012
#523: SymDifference between two valid geometries return an _invalid_ geometry
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.3
Component: Default | Version: 3.3.2
Severity: Unassigned | Keywords:
Geometry A:
010300000001000000080000000000000087523A41000000402C62524100000000B0523A41000000C01E6252410000000084523A41000000C023625241858C4F2488523A4151F8EEAC2562524111A0F52288523A414F50F3AC25625241D59FF52288523A414F50F3AC25625241000000007F523A4100000080256252410000000087523A41000000402C625241
Geometry B:
01030000000100000004000000A871502388523A4158FEF2AC2562524100A0F52288523A414F50F3AC2562524111A0F52288523A414F50F3AC25625241A871502388523A4158FEF2AC25625241
They are both valid, but when running SymDifference against them the
result is invalid.
Ticket URL: <http://trac.osgeo.org/geos/ticket/523>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
