[geos-devel] Re: [GEOS] #523: SymDifference between two valid
geometries return an _invalid_ geometry
geos-trac at osgeo.org
Fri Mar 30 06:32:18 EDT 2012
#523: SymDifference between two valid geometries return an _invalid_ geometry
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.3
Component: Default | Version: 3.3.2
Severity: Unassigned | Keywords:
Comment(by strk):
The inputs are a larger polygon (first) and a very narrow polygon almost
collapsed to a line which intersects with the former.
Areas:
839.745285423078
3.86746841149477e-14
Overlay with original input fails: TopologyException: found non-noded
intersection between LINESTRING (1.72506e+06 4.81909e+06, 1.72506e+06
4.81909e+06) and LINESTRING (1.72506e+06 4.81909e+06, 1.72506e+06
4.81909e+06) at 1725064.1365604463 4819094.70235069
Common-bits remover result is refused due to invalidity of the output.
Snap heuristic is accepted no matter invalidity of the output.
Invalidity is (in both cases): Self-intersection at or near point
1725064.1365604463 4819094.70235069 (1725064.1365604463499
4819094.7023506900296)
I guess it'd make more sense to throw a TopologyException on invalid
output.. but that's really something that shouldn't happen.
Ticket URL: <http://trac.osgeo.org/geos/ticket/523#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
